Time Before: 0.01456 seconds
Time After: 0.01913 seconds
Time Taken: 0.00457 seconds
Time Before: 0.01920 seconds
Time After: 0.01963 seconds
Time Before: 0.01987 seconds
Time After: 0.02002 seconds
Time Before: 0.02090 seconds
Time After: 0.02319 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02010 seconds
Time After: 0.02768 seconds
Time Taken: 0.00758 seconds
Time Before: 0.03598 seconds
Time After: 0.03645 seconds
Time Before: 0.03942 seconds
Time After: 0.04060 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03520 seconds
Time After: 0.04085 seconds
Time Taken: 0.00565 seconds
Time Before: 0.07535 seconds
Time After: 0.07549 seconds
Time Before: 0.09082 seconds
Time After: 0.09208 seconds
Time Before: 0.10413 seconds
Time After: 0.10428 seconds
Time Before: 0.10675 seconds
Time After: 0.10820 seconds
UPDATE session SET lastactivity = 1772951902, location = '/forums/private.php?do=newpm&explain=1&u=96168' WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.12686 seconds
Time After: 0.12718 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
