Time Before: 0.00594 seconds
Time After: 0.00750 seconds
Time Taken: 0.00156 seconds
Time Before: 0.00760 seconds
Time After: 0.00804 seconds
Time Before: 0.00827 seconds
Time After: 0.00842 seconds
Time Before: 0.00920 seconds
Time After: 0.01145 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00848 seconds
Time After: 0.01531 seconds
Time Taken: 0.00683 seconds
Time Before: 0.01865 seconds
Time After: 0.01903 seconds
Time Before: 0.02209 seconds
Time After: 0.02329 seconds
Time Before: 0.01811 seconds
Time After: 0.02352 seconds
Time Taken: 0.00541 seconds
Time Before: 0.03515 seconds
Time After: 0.03531 seconds
Time Before: 0.04005 seconds
Time After: 0.04128 seconds
Time Before: 0.04619 seconds
Time After: 0.04638 seconds
Time Before: 0.04940 seconds
Time After: 0.05091 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1783106367, location = '/forums/private.php?do=newpm&explain=1&u=96194' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.07099 seconds
Time After: 0.07137 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
