Time Before: 0.00159 seconds
Time After: 0.00210 seconds
Time Before: 0.00221 seconds
Time After: 0.00267 seconds
Time Before: 0.00294 seconds
Time After: 0.00314 seconds
Time Before: 0.00396 seconds
Time After: 0.00830 seconds
Time Taken: 0.00434 seconds
Time Before: 0.00319 seconds
Time After: 0.01197 seconds
Time Taken: 0.00878 seconds
Time Before: 0.01468 seconds
Time After: 0.01513 seconds
Time Before: 0.01803 seconds
Time After: 0.01926 seconds
Time Before: 0.01399 seconds
Time After: 0.01950 seconds
Time Taken: 0.00551 seconds
Time Before: 0.02682 seconds
Time After: 0.02726 seconds
Time Before: 0.02940 seconds
Time After: 0.03071 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.032387971878052
Time Before: 0.03368 seconds
Time After: 0.03392 seconds
Time Before: 0.03691 seconds
Time After: 0.03839 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=96252'
Time Before: 0.05089 seconds
Time After: 0.05112 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049972057342529 seconds with 9 queries, spending 0.010360479354858 doing MySQL queries and 0.039611577987671 doing PHP things.
