Time Before: 0.00131 seconds
Time After: 0.00175 seconds
Time Before: 0.00182 seconds
Time After: 0.00219 seconds
Time Before: 0.00237 seconds
Time After: 0.00251 seconds
Time Before: 0.00310 seconds
Time After: 0.00561 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00256 seconds
Time After: 0.01048 seconds
Time Taken: 0.00792 seconds
Time Before: 0.01246 seconds
Time After: 0.01283 seconds
Time Before: 0.01495 seconds
Time After: 0.01616 seconds
Time Before: 0.01177 seconds
Time After: 0.01638 seconds
Time Taken: 0.00461 seconds
Time Before: 0.02291 seconds
Time After: 0.02308 seconds
Time Before: 0.02528 seconds
Time After: 0.02652 seconds
End call of global.php: 0.029038906097412
Time Before: 0.03038 seconds
Time After: 0.03055 seconds
Time Before: 0.03305 seconds
Time After: 0.03458 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=96418', badlocation = 1
Time Before: 0.05182 seconds
Time After: 0.05220 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.050900936126709 seconds with 9 queries, spending 0.0080835819244385 doing MySQL queries and 0.042817354202271 doing PHP things.
