Time Before: 0.01203 seconds
Time After: 0.01655 seconds
Time Taken: 0.00452 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01667 seconds
Time After: 0.01758 seconds
Time Taken: 0.00091 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01814 seconds
Time After: 0.01831 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01924 seconds
Time After: 0.02218 seconds
Time Taken: 0.00293 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01841 seconds
Time After: 0.02693 seconds
Time Taken: 0.00852 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03428 seconds
Time After: 0.03468 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03612 seconds
Time After: 0.03734 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.03355 seconds
Time After: 0.03754 seconds
Time Taken: 0.00400 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.06772 seconds
Time After: 0.06785 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.10738 seconds
Time After: 0.10865 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.12685 seconds
Time After: 0.12704 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.13020 seconds
Time After: 0.13165 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1773320608, location = '/forums/private.php?do=newpm&explain=1&u=96513', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.15489 seconds
Time After: 0.15567 seconds
Time Taken: 0.00078 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
