Time Before: 0.01174 seconds
Time After: 0.01441 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01455 seconds
Time After: 0.01497 seconds
Time Before: 0.01521 seconds
Time After: 0.01531 seconds
Time Before: 0.01606 seconds
Time After: 0.01857 seconds
Time Taken: 0.00251 seconds
Time Before: 0.01537 seconds
Time After: 0.02257 seconds
Time Taken: 0.00720 seconds
Time Before: 0.02824 seconds
Time After: 0.02861 seconds
Time Before: 0.03101 seconds
Time After: 0.03221 seconds
Time Before: 0.02757 seconds
Time After: 0.03238 seconds
Time Taken: 0.00481 seconds
Time Before: 0.05282 seconds
Time After: 0.05299 seconds
Time Before: 0.06295 seconds
Time After: 0.06420 seconds
Time Before: 0.07177 seconds
Time After: 0.07193 seconds
Time Before: 0.07480 seconds
Time After: 0.07636 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=96613', badlocation = 1 WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.09228 seconds
Time After: 0.09253 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
