Time Before: 0.01008 seconds
Time After: 0.01268 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01276 seconds
Time After: 0.01316 seconds
Time Before: 0.01340 seconds
Time After: 0.01357 seconds
Time Before: 0.01424 seconds
Time After: 0.01689 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01362 seconds
Time After: 0.02029 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02473 seconds
Time After: 0.02515 seconds
Time Before: 0.02795 seconds
Time After: 0.02929 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02408 seconds
Time After: 0.02949 seconds
Time Taken: 0.00541 seconds
Memory After: 2,261.836 KB
Time Before: 0.04857 seconds
Time After: 0.04884 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05694 seconds
Time After: 0.05863 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.060444116592407
Time Before: 0.06380 seconds
Time After: 0.06409 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06608 seconds
Time After: 0.06752 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789140199, location = '/forums/private.php?do=newpm&explain=1&u=96630'
Time Before: 0.08518 seconds
Time After: 0.08547 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.08400297164917 seconds with 9 queries, spending 0.0089788436889648 doing MySQL queries and 0.075024127960205 doing PHP things.
