Time Before: 0.00135 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00254 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00280 seconds
Time After: 0.00295 seconds
Time Before: 0.00361 seconds
Time After: 0.00658 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00300 seconds
Time After: 0.01032 seconds
Time Taken: 0.00731 seconds
Time Before: 0.01224 seconds
Time After: 0.01275 seconds
Time Before: 0.01513 seconds
Time After: 0.01667 seconds
Time Taken: 0.00154 seconds
Time Before: 0.01158 seconds
Time After: 0.01691 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02316 seconds
Time After: 0.02329 seconds
Time Before: 0.02588 seconds
Time After: 0.02709 seconds
End call of global.php: 0.028808116912842
Time Before: 0.03000 seconds
Time After: 0.03014 seconds
Time Before: 0.03211 seconds
Time After: 0.03352 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=96912', badlocation = 1
WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.04592 seconds
Time After: 0.04620 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.045015096664429 seconds with 9 queries, spending 0.0089449882507324 doing MySQL queries and 0.036070108413696 doing PHP things.
