Time Before: 0.00174 seconds
Time After: 0.00225 seconds
Time Before: 0.00232 seconds
Time After: 0.00269 seconds
Time Before: 0.00294 seconds
Time After: 0.00305 seconds
Time Before: 0.00367 seconds
Time After: 0.00693 seconds
Time Taken: 0.00325 seconds
Time Before: 0.00310 seconds
Time After: 0.01052 seconds
Time Taken: 0.00742 seconds
Time Before: 0.01243 seconds
Time After: 0.01286 seconds
Time Before: 0.01626 seconds
Time After: 0.01828 seconds
Time Taken: 0.00201 seconds
Time Before: 0.01176 seconds
Time After: 0.01851 seconds
Time Taken: 0.00676 seconds
Time Before: 0.02577 seconds
Time After: 0.02590 seconds
Time Before: 0.02780 seconds
Time After: 0.02938 seconds
Time Taken: 0.00158 seconds
End call of global.php: 0.031991004943848
Time Before: 0.03368 seconds
Time After: 0.03383 seconds
Time Before: 0.03696 seconds
Time After: 0.03842 seconds
SET lastactivity = 1789134784, location = '/forums/private.php?do=newpm&explain=1&u=97039'
Time Before: 0.05168 seconds
Time After: 0.05219 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.05074405670166 seconds with 9 queries, spending 0.010016918182373 doing MySQL queries and 0.040727138519287 doing PHP things.
