Time Before: 0.01146 seconds
Time After: 0.01496 seconds
Time Taken: 0.00350 seconds
Time Before: 0.01505 seconds
Time After: 0.01563 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01589 seconds
Time After: 0.01604 seconds
Time Before: 0.01680 seconds
Time After: 0.01969 seconds
Time Taken: 0.00289 seconds
Time Before: 0.01611 seconds
Time After: 0.02428 seconds
Time Taken: 0.00816 seconds
Time Before: 0.02953 seconds
Time After: 0.02998 seconds
Time Before: 0.03263 seconds
Time After: 0.03392 seconds
Time Before: 0.02857 seconds
Time After: 0.03418 seconds
Time Taken: 0.00561 seconds
Time Before: 0.05430 seconds
Time After: 0.05446 seconds
Time Before: 0.05977 seconds
Time After: 0.06110 seconds
Time Taken: 0.00134 seconds
Time Before: 0.06580 seconds
Time After: 0.06596 seconds
Time Before: 0.06813 seconds
Time After: 0.06962 seconds
UPDATE session SET lastactivity = 1785361234, location = '/forums/private.php?do=newpm&explain=1&u=97137' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08801 seconds
Time After: 0.08832 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
