Time Before: 0.00130 seconds
Time After: 0.00176 seconds
Time Before: 0.00182 seconds
Time After: 0.00221 seconds
Time Before: 0.00245 seconds
Time After: 0.00258 seconds
Time Before: 0.00327 seconds
Time After: 0.00537 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00262 seconds
Time After: 0.00879 seconds
Time Taken: 0.00616 seconds
Time Before: 0.01075 seconds
Time After: 0.01094 seconds
Time Before: 0.01415 seconds
Time After: 0.01538 seconds
Time Before: 0.01012 seconds
Time After: 0.01556 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02075 seconds
Time After: 0.02095 seconds
Time Before: 0.02299 seconds
Time After: 0.02422 seconds
End call of global.php: 0.025982141494751
Time Before: 0.02819 seconds
Time After: 0.02836 seconds
Time Before: 0.03048 seconds
Time After: 0.03191 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=97360'
Time Before: 0.04442 seconds
Time After: 0.04468 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.043511152267456 seconds with 9 queries, spending 0.0073311328887939 doing MySQL queries and 0.036180019378662 doing PHP things.
