Time Before: 0.00233 seconds
Time After: 0.00298 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00308 seconds
Time After: 0.00354 seconds
Time Before: 0.00388 seconds
Time After: 0.00403 seconds
Time Before: 0.00508 seconds
Time After: 0.00829 seconds
Time Taken: 0.00321 seconds
Time Before: 0.00411 seconds
Time After: 0.01354 seconds
Time Taken: 0.00943 seconds
Time Before: 0.01639 seconds
Time After: 0.01680 seconds
Time Before: 0.01935 seconds
Time After: 0.02056 seconds
Time Before: 0.01568 seconds
Time After: 0.02080 seconds
Time Taken: 0.00513 seconds
Time Before: 0.03572 seconds
Time After: 0.03588 seconds
Time Before: 0.04282 seconds
Time After: 0.04410 seconds
End call of global.php: 0.046610116958618
Time Before: 0.04956 seconds
Time After: 0.04971 seconds
Time Before: 0.05303 seconds
Time After: 0.05446 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=97727', badlocation = 1
WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.07558 seconds
Time After: 0.07589 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.074012041091919 seconds with 9 queries, spending 0.0087692737579346 doing MySQL queries and 0.065242767333984 doing PHP things.
