Time Before: 0.00242 seconds
Time After: 0.00303 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00310 seconds
Time After: 0.00362 seconds
Time Before: 0.00382 seconds
Time After: 0.00394 seconds
Time Before: 0.00470 seconds
Time After: 0.00696 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00399 seconds
Time After: 0.01068 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01400 seconds
Time After: 0.01442 seconds
Time Before: 0.01717 seconds
Time After: 0.01954 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01312 seconds
Time After: 0.01980 seconds
Time Before: 0.02787 seconds
Time After: 0.02806 seconds
Time Before: 0.03137 seconds
Time After: 0.03268 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03760 seconds
Time After: 0.03800 seconds
Time Before: 0.04132 seconds
Time After: 0.04286 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=97834' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06396 seconds
Time After: 0.06421 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
