Time Before: 0.01072 seconds
Time After: 0.01408 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01417 seconds
Time After: 0.01478 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01502 seconds
Time After: 0.01516 seconds
Time Before: 0.01593 seconds
Time After: 0.01854 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01521 seconds
Time After: 0.02243 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02667 seconds
Time After: 0.02691 seconds
Time Before: 0.02954 seconds
Time After: 0.03088 seconds
Time Taken: 0.00134 seconds
Time Before: 0.02594 seconds
Time After: 0.03109 seconds
Time Taken: 0.00514 seconds
Time Before: 0.04965 seconds
Time After: 0.04981 seconds
Time Before: 0.05866 seconds
Time After: 0.06000 seconds
Time Before: 0.06640 seconds
Time After: 0.06659 seconds
Time Before: 0.06896 seconds
Time After: 0.07048 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1776985713, location = '/forums/private.php?do=newpm&explain=1&u=97856', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.08433 seconds
Time After: 0.08461 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
