Time Before: 0.00832 seconds
Time After: 0.01083 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01093 seconds
Time After: 0.01141 seconds
Time Before: 0.01164 seconds
Time After: 0.01179 seconds
Time Before: 0.01248 seconds
Time After: 0.01524 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01185 seconds
Time After: 0.02075 seconds
Time Taken: 0.00890 seconds
Time Before: 0.02627 seconds
Time After: 0.02672 seconds
Time Before: 0.02996 seconds
Time After: 0.03118 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02531 seconds
Time After: 0.03143 seconds
Time Taken: 0.00612 seconds
Memory After: 2,261.719 KB
Time Before: 0.04498 seconds
Time After: 0.04511 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05637 seconds
Time After: 0.05761 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.060067892074585
Time Before: 0.06390 seconds
Time After: 0.06407 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06653 seconds
Time After: 0.06795 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=97889'
Time Before: 0.08602 seconds
Time After: 0.08627 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.084753036499023 seconds with 9 queries, spending 0.0082757472991943 doing MySQL queries and 0.076477289199829 doing PHP things.
