Time Before: 0.00184 seconds
Time After: 0.00237 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00244 seconds
Time After: 0.00301 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00329 seconds
Time After: 0.00349 seconds
Time Before: 0.00422 seconds
Time After: 0.00710 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00355 seconds
Time After: 0.01196 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01605 seconds
Time After: 0.01663 seconds
Time Before: 0.01923 seconds
Time After: 0.02045 seconds
Time Before: 0.01487 seconds
Time After: 0.02064 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02585 seconds
Time After: 0.02600 seconds
Time Before: 0.02852 seconds
Time After: 0.02981 seconds
Time Before: 0.03402 seconds
Time After: 0.03430 seconds
Time Before: 0.03642 seconds
Time After: 0.03789 seconds
UPDATE session SET lastactivity = 1785292206, location = '/forums/private.php?do=newpm&explain=1&u=97897', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05327 seconds
Time After: 0.05365 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
