Time Before: 0.01366 seconds
Time After: 0.01726 seconds
Time Taken: 0.00360 seconds
Time Before: 0.01737 seconds
Time After: 0.01779 seconds
Time Before: 0.01803 seconds
Time After: 0.01818 seconds
Time Before: 0.01888 seconds
Time After: 0.02127 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01823 seconds
Time After: 0.02575 seconds
Time Taken: 0.00751 seconds
Time Before: 0.03217 seconds
Time After: 0.03255 seconds
Time Before: 0.03511 seconds
Time After: 0.03633 seconds
Time Before: 0.03156 seconds
Time After: 0.03652 seconds
Time Taken: 0.00496 seconds
Time Before: 0.05952 seconds
Time After: 0.05967 seconds
Time Before: 0.07256 seconds
Time After: 0.07382 seconds
Time Before: 0.08126 seconds
Time After: 0.08140 seconds
Time Before: 0.08390 seconds
Time After: 0.08537 seconds
UPDATE session SET lastactivity = 1782843104, location = '/forums/private.php?do=newpm&explain=1&u=97919' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.10262 seconds
Time After: 0.10306 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
