Time Before: 0.00193 seconds
Time After: 0.00241 seconds
Time Before: 0.00248 seconds
Time After: 0.00292 seconds
Time Before: 0.00320 seconds
Time After: 0.00334 seconds
Time Before: 0.00423 seconds
Time After: 0.00885 seconds
Time Taken: 0.00462 seconds
Time Before: 0.00341 seconds
Time After: 0.01227 seconds
Time Taken: 0.00885 seconds
Time Before: 0.01421 seconds
Time After: 0.01465 seconds
Time Before: 0.01623 seconds
Time After: 0.01744 seconds
Time Before: 0.01358 seconds
Time After: 0.01762 seconds
Time Taken: 0.00404 seconds
Time Before: 0.02272 seconds
Time After: 0.02286 seconds
Time Before: 0.02497 seconds
Time After: 0.02626 seconds
End call of global.php: 0.027853965759277
Time Before: 0.02905 seconds
Time After: 0.02920 seconds
Time Before: 0.03121 seconds
Time After: 0.03280 seconds
Time Taken: 0.00159 seconds
SET lastactivity = 1785342976, location = '/forums/private.php?do=newpm&explain=1&u=97971', badlocation = 1
Time Before: 0.04508 seconds
Time After: 0.04540 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.044189929962158 seconds with 9 queries, spending 0.01033091545105 doing MySQL queries and 0.033859014511108 doing PHP things.
