Time Before: 0.00514 seconds
Time After: 0.00652 seconds
Time Taken: 0.00138 seconds
Time Before: 0.00662 seconds
Time After: 0.00704 seconds
Time Before: 0.00728 seconds
Time After: 0.00741 seconds
Time Before: 0.00828 seconds
Time After: 0.01159 seconds
Time Taken: 0.00331 seconds
Time Before: 0.00749 seconds
Time After: 0.01726 seconds
Time Taken: 0.00977 seconds
Time Before: 0.02012 seconds
Time After: 0.02057 seconds
Time Before: 0.02387 seconds
Time After: 0.02527 seconds
Time Before: 0.01941 seconds
Time After: 0.02554 seconds
Time Taken: 0.00613 seconds
Time Before: 0.03095 seconds
Time After: 0.03109 seconds
Time Before: 0.03293 seconds
Time After: 0.03420 seconds
End call of global.php: 0.03595495223999
Time Before: 0.03751 seconds
Time After: 0.03765 seconds
Time Before: 0.03986 seconds
Time After: 0.04146 seconds
Time Taken: 0.00160 seconds
SET lastactivity = 1789045007, location = '/forums/private.php?do=newpm&explain=1&u=9801', badlocation = 1
Time Before: 0.05435 seconds
Time After: 0.05477 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
Page generated in 0.053410053253174 seconds with 9 queries, spending 0.0092825889587402 doing MySQL queries and 0.044127464294434 doing PHP things.
