Time Before: 0.00208 seconds
Time After: 0.00264 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00274 seconds
Time After: 0.00311 seconds
Time Before: 0.00334 seconds
Time After: 0.00346 seconds
Time Before: 0.00433 seconds
Time After: 0.00729 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00355 seconds
Time After: 0.01191 seconds
Time Taken: 0.00836 seconds
Time Before: 0.01390 seconds
Time After: 0.01438 seconds
Time Before: 0.01686 seconds
Time After: 0.01815 seconds
Time Before: 0.01323 seconds
Time After: 0.01833 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02358 seconds
Time After: 0.02375 seconds
Time Before: 0.02601 seconds
Time After: 0.02745 seconds
End call of global.php: 0.030030965805054
Time Before: 0.03203 seconds
Time After: 0.03217 seconds
Time Before: 0.03547 seconds
Time After: 0.03690 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=98021', badlocation = 1
Time Before: 0.05132 seconds
Time After: 0.05171 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.050378084182739 seconds with 9 queries, spending 0.0088050365447998 doing MySQL queries and 0.041573047637939 doing PHP things.
