Time Before: 0.01252 seconds
Time After: 0.01661 seconds
Time Taken: 0.00409 seconds
Time Before: 0.01671 seconds
Time After: 0.01705 seconds
Time Before: 0.01723 seconds
Time After: 0.01734 seconds
Time Before: 0.01811 seconds
Time After: 0.02028 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01742 seconds
Time After: 0.02447 seconds
Time Taken: 0.00705 seconds
Time Before: 0.02981 seconds
Time After: 0.03001 seconds
Time Before: 0.03239 seconds
Time After: 0.03362 seconds
Time Before: 0.02904 seconds
Time After: 0.03382 seconds
Time Taken: 0.00478 seconds
Time Before: 0.05667 seconds
Time After: 0.05686 seconds
Time Before: 0.06703 seconds
Time After: 0.06828 seconds
End call of global.php: 0.070716142654419
Time Before: 0.07497 seconds
Time After: 0.07516 seconds
Time Before: 0.07761 seconds
Time After: 0.07908 seconds
SET lastactivity = 1776751234, location = '/forums/private.php?do=newpm&explain=1&u=98061'
Time Before: 0.09638 seconds
Time After: 0.09677 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.095185995101929 seconds with 9 queries, spending 0.0075480937957764 doing MySQL queries and 0.087637901306152 doing PHP things.
