Time Before: 0.03238 seconds
Time After: 0.03822 seconds
Time Taken: 0.00584 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.03832 seconds
Time After: 0.03885 seconds
Time Taken: 0.00053 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.03908 seconds
Time After: 0.03922 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.04027 seconds
Time After: 0.04314 seconds
Time Taken: 0.00287 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.03928 seconds
Time After: 0.04777 seconds
Time Taken: 0.00848 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.06243 seconds
Time After: 0.06299 seconds
Time Taken: 0.00055 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.06581 seconds
Time After: 0.06707 seconds
Memory Before: 2,146.828 KB
Memory After: 2,146.688 KB
Time Before: 0.06118 seconds
Time After: 0.06738 seconds
Time Taken: 0.00620 seconds
Memory Before: 2,126.828 KB
Memory After: 2,260.039 KB
Memory Used: 133.211 KB
Time Before: 0.10501 seconds
Time After: 0.10516 seconds
Memory Before: 2,813.602 KB
Memory After: 2,814.117 KB
Time Before: 0.14093 seconds
Time After: 0.14220 seconds
Memory Before: 2,901.891 KB
Memory After: 2,902.484 KB
End call of global.php: 0.14436411857605
Time Before: 0.15794 seconds
Time After: 0.15814 seconds
Memory Before: 3,538.641 KB
Memory After: 3,539.070 KB
Time Before: 0.16172 seconds
Time After: 0.16331 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,820.375 KB
Memory After: 3,822.063 KB
SET lastactivity = 1788984849, location = '/forums/private.php?do=newpm&explain=1&u=98089', badlocation = 1
Time Before: 0.18625 seconds
Time After: 0.18667 seconds
Memory Before: 4,298.813 KB
Memory After: 4,299.023 KB
Page generated in 0.18513607978821 seconds with 9 queries, spending 0.0089643001556396 doing MySQL queries and 0.17617177963257 doing PHP things.
