Time Before: 0.02617 seconds
Time After: 0.03621 seconds
Time Taken: 0.01005 seconds
Memory Before: 1,245.586 KB
Memory After: 1,272.391 KB
Time Before: 0.03633 seconds
Time After: 0.03678 seconds
Memory Before: 1,272.352 KB
Memory After: 1,273.328 KB
Time Before: 0.03712 seconds
Time After: 0.03724 seconds
Memory Before: 1,273.969 KB
Memory After: 1,274.492 KB
Time Before: 0.03807 seconds
Time After: 0.04063 seconds
Time Taken: 0.00256 seconds
Memory Before: 1,277.359 KB
Memory After: 1,278.281 KB
Time Before: 0.03731 seconds
Time After: 0.04465 seconds
Time Taken: 0.00734 seconds
Memory Before: 1,273.773 KB
Memory After: 2,354.992 KB
Memory Used: 1,081.219 KB
Time Before: 0.05727 seconds
Time After: 0.05771 seconds
Memory Before: 2,895.180 KB
Memory After: 2,895.797 KB
Time Before: 0.06088 seconds
Time After: 0.06206 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,907.625 KB
Memory After: 2,907.484 KB
Time Before: 0.05649 seconds
Time After: 0.06231 seconds
Time Taken: 0.00582 seconds
Memory Before: 2,887.906 KB
Memory After: 3,020.539 KB
Memory Used: 132.633 KB
Time Before: 0.10602 seconds
Time After: 0.10642 seconds
Memory Before: 3,655.133 KB
Memory After: 3,655.648 KB
Time Before: 0.15830 seconds
Time After: 0.15954 seconds
Memory Before: 4,132.766 KB
Memory After: 4,133.359 KB
Time Before: 0.18969 seconds
Time After: 0.18984 seconds
Memory Before: 5,196.992 KB
Memory After: 5,325.336 KB
Time Before: 0.19470 seconds
Time After: 0.19626 seconds
Time Taken: 0.00156 seconds
Memory Before: 5,480.703 KB
Memory After: 5,610.305 KB
UPDATE session SET lastactivity = 1772886043, location = '/forums/private.php?do=newpm&explain=1&u=98155' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.21921 seconds
Time After: 0.21951 seconds
Memory Before: 6,006.148 KB
Memory After: 6,006.375 KB
