Time Before: 0.00221 seconds
Time After: 0.00274 seconds
Time Before: 0.00281 seconds
Time After: 0.00322 seconds
Time Before: 0.00340 seconds
Time After: 0.00357 seconds
Time Before: 0.00420 seconds
Time After: 0.00698 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00362 seconds
Time After: 0.01042 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01224 seconds
Time After: 0.01265 seconds
Time Before: 0.01394 seconds
Time After: 0.01518 seconds
Time Before: 0.01170 seconds
Time After: 0.01535 seconds
Time Taken: 0.00365 seconds
Time Before: 0.02050 seconds
Time After: 0.02065 seconds
Time Before: 0.02321 seconds
Time After: 0.02449 seconds
End call of global.php: 0.026892900466919
Time Before: 0.02833 seconds
Time After: 0.02850 seconds
Time Before: 0.03131 seconds
Time After: 0.03280 seconds
SET lastactivity = 1776709446, location = '/forums/private.php?do=newpm&explain=1&u=98177'
Time Before: 0.04939 seconds
Time After: 0.04972 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048424959182739 seconds with 9 queries, spending 0.0084314346313477 doing MySQL queries and 0.039993524551392 doing PHP things.
