Time Before: 0.00219 seconds
Time After: 0.00287 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00294 seconds
Time After: 0.00336 seconds
Time Before: 0.00362 seconds
Time After: 0.00375 seconds
Time Before: 0.00455 seconds
Time After: 0.00719 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00381 seconds
Time After: 0.01178 seconds
Time Taken: 0.00796 seconds
Time Before: 0.01479 seconds
Time After: 0.01520 seconds
Time Before: 0.01780 seconds
Time After: 0.01898 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01402 seconds
Time After: 0.01923 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02705 seconds
Time After: 0.02726 seconds
Time Before: 0.02983 seconds
Time After: 0.03111 seconds
End call of global.php: 0.033218145370483
Time Before: 0.03475 seconds
Time After: 0.03491 seconds
Time Before: 0.03750 seconds
Time After: 0.03899 seconds
SET lastactivity = 1789032702, location = '/forums/private.php?do=newpm&explain=1&u=98256'
Time Before: 0.05215 seconds
Time After: 0.05236 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.051219940185547 seconds with 9 queries, spending 0.0081260204315186 doing MySQL queries and 0.043093919754028 doing PHP things.
