Time Before: 0.00750 seconds
Time After: 0.01026 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01033 seconds
Time After: 0.01085 seconds
Time Before: 0.01106 seconds
Time After: 0.01117 seconds
Time Before: 0.01187 seconds
Time After: 0.01450 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01124 seconds
Time After: 0.01936 seconds
Time Taken: 0.00812 seconds
Time Before: 0.02375 seconds
Time After: 0.02414 seconds
Time Before: 0.02563 seconds
Time After: 0.02716 seconds
Time Taken: 0.00153 seconds
Time Before: 0.02285 seconds
Time After: 0.02749 seconds
Time Taken: 0.00464 seconds
Time Before: 0.04555 seconds
Time After: 0.04573 seconds
Time Before: 0.05469 seconds
Time After: 0.05607 seconds
Time Taken: 0.00138 seconds
End call of global.php: 0.058336973190308
Time Before: 0.06327 seconds
Time After: 0.06344 seconds
Time Before: 0.06613 seconds
Time After: 0.06766 seconds
SET lastactivity = 1776700407, location = '/forums/private.php?do=newpm&explain=1&u=9828'
Time Before: 0.08536 seconds
Time After: 0.08562 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
Page generated in 0.084292888641357 seconds with 9 queries, spending 0.0086884498596191 doing MySQL queries and 0.075604438781738 doing PHP things.
