Time Before: 0.01070 seconds
Time After: 0.01433 seconds
Time Taken: 0.00363 seconds
Time Before: 0.01442 seconds
Time After: 0.01478 seconds
Time Before: 0.01497 seconds
Time After: 0.01512 seconds
Time Before: 0.01599 seconds
Time After: 0.01859 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01522 seconds
Time After: 0.02362 seconds
Time Taken: 0.00840 seconds
Time Before: 0.02784 seconds
Time After: 0.02820 seconds
Time Before: 0.03085 seconds
Time After: 0.03201 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02712 seconds
Time After: 0.03223 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.719 KB
Time Before: 0.04708 seconds
Time After: 0.04726 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05659 seconds
Time After: 0.05783 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.06433 seconds
Time After: 0.06452 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06722 seconds
Time After: 0.06867 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=98341' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.08587 seconds
Time After: 0.08623 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
