Time Before: 0.01335 seconds
Time After: 0.02008 seconds
Time Taken: 0.00673 seconds
Time Before: 0.02018 seconds
Time After: 0.02107 seconds
Time Taken: 0.00089 seconds
Time Before: 0.02141 seconds
Time After: 0.02165 seconds
Time Before: 0.02294 seconds
Time After: 0.02950 seconds
Time Taken: 0.00656 seconds
Time Before: 0.02173 seconds
Time After: 0.03505 seconds
Time Taken: 0.01332 seconds
Time Before: 0.04883 seconds
Time After: 0.04908 seconds
Time Before: 0.05217 seconds
Time After: 0.05332 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04815 seconds
Time After: 0.05352 seconds
Time Taken: 0.00538 seconds
Time Before: 0.07704 seconds
Time After: 0.07718 seconds
Time Before: 0.44805 seconds
Time After: 0.44942 seconds
Time Taken: 0.00137 seconds
Time Before: 0.46087 seconds
Time After: 0.46125 seconds
Time Before: 0.46392 seconds
Time After: 0.46533 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=98362', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.48651 seconds
Time After: 0.48675 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
