Time Before: 0.00340 seconds
Time After: 0.00496 seconds
Time Taken: 0.00155 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.00505 seconds
Time After: 0.00545 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.00565 seconds
Time After: 0.00582 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.00678 seconds
Time After: 0.00904 seconds
Time Taken: 0.00226 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.00590 seconds
Time After: 0.01401 seconds
Time Taken: 0.00811 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.01749 seconds
Time After: 0.01793 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.02120 seconds
Time After: 0.02244 seconds
Memory Before: 2,147.406 KB
Memory After: 2,147.266 KB
Time Before: 0.01661 seconds
Time After: 0.02278 seconds
Time Taken: 0.00617 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.617 KB
Memory Used: 133.094 KB
Time Before: 0.03696 seconds
Time After: 0.03712 seconds
Memory Before: 2,814.227 KB
Memory After: 2,814.742 KB
Time Before: 0.04185 seconds
Time After: 0.04313 seconds
Memory Before: 2,902.547 KB
Memory After: 2,903.141 KB
End call of global.php: 0.045469999313354
Time Before: 0.04800 seconds
Time After: 0.04814 seconds
Memory Before: 3,539.352 KB
Memory After: 3,539.781 KB
Time Before: 0.05079 seconds
Time After: 0.05235 seconds
Memory Before: 3,820.883 KB
Memory After: 3,822.570 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=98365'
Time Before: 0.06676 seconds
Time After: 0.06701 seconds
Memory Before: 4,298.938 KB
Memory After: 4,299.172 KB
Memory Used: 0.234 KB
Page generated in 0.06564998626709 seconds with 9 queries, spending 0.0078742504119873 doing MySQL queries and 0.057775735855103 doing PHP things.
