Time Before: 0.00143 seconds
Time After: 0.00197 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00205 seconds
Time After: 0.00250 seconds
Time Before: 0.00272 seconds
Time After: 0.00286 seconds
Time Before: 0.00368 seconds
Time After: 0.00630 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00292 seconds
Time After: 0.01102 seconds
Time Taken: 0.00809 seconds
Time Before: 0.01301 seconds
Time After: 0.01343 seconds
Time Before: 0.01592 seconds
Time After: 0.01711 seconds
Time Before: 0.01242 seconds
Time After: 0.01733 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02346 seconds
Time After: 0.02359 seconds
Time Before: 0.02584 seconds
Time After: 0.02708 seconds
Time Before: 0.03031 seconds
Time After: 0.03045 seconds
Time Before: 0.03256 seconds
Time After: 0.03402 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=98380' WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04752 seconds
Time After: 0.04781 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
