Time Before: 0.00789 seconds
Time After: 0.01477 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01484 seconds
Time After: 0.01542 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01567 seconds
Time After: 0.01586 seconds
Time Before: 0.01660 seconds
Time After: 0.01932 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01592 seconds
Time After: 0.02339 seconds
Time Taken: 0.00747 seconds
Time Before: 0.03258 seconds
Time After: 0.03305 seconds
Time Before: 0.03579 seconds
Time After: 0.03703 seconds
Time Before: 0.03180 seconds
Time After: 0.03724 seconds
Time Taken: 0.00544 seconds
Time Before: 0.05772 seconds
Time After: 0.05791 seconds
Time Before: 0.08128 seconds
Time After: 0.08256 seconds
Time Before: 0.09510 seconds
Time After: 0.09529 seconds
Time Before: 0.09794 seconds
Time After: 0.10024 seconds
Time Taken: 0.00230 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=98409', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.11869 seconds
Time After: 0.11899 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
