Time Before: 0.02270 seconds
Time After: 0.03415 seconds
Time Taken: 0.01145 seconds
Time Before: 0.03429 seconds
Time After: 0.03477 seconds
Time Before: 0.03505 seconds
Time After: 0.03526 seconds
Time Before: 0.03601 seconds
Time After: 0.03858 seconds
Time Taken: 0.00257 seconds
Time Before: 0.03532 seconds
Time After: 0.04309 seconds
Time Taken: 0.00777 seconds
Time Before: 0.05392 seconds
Time After: 0.05413 seconds
Time Before: 0.05681 seconds
Time After: 0.05834 seconds
Time Taken: 0.00153 seconds
Time Before: 0.05322 seconds
Time After: 0.05859 seconds
Time Taken: 0.00537 seconds
Time Before: 0.08432 seconds
Time After: 0.08448 seconds
Time Before: 0.57786 seconds
Time After: 0.57957 seconds
Time Taken: 0.00171 seconds
Time Before: 0.59258 seconds
Time After: 0.59274 seconds
Time Before: 0.59541 seconds
Time After: 0.59688 seconds
UPDATE session SET lastactivity = 1776631606, location = '/forums/private.php?do=newpm&explain=1&u=98423', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.61594 seconds
Time After: 0.61622 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
