Time Before: 0.00149 seconds
Time After: 0.00198 seconds
Time Before: 0.00207 seconds
Time After: 0.00259 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00284 seconds
Time After: 0.00305 seconds
Time Before: 0.00368 seconds
Time After: 0.00615 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00310 seconds
Time After: 0.00952 seconds
Time Taken: 0.00642 seconds
Time Before: 0.01127 seconds
Time After: 0.01145 seconds
Time Before: 0.01403 seconds
Time After: 0.01526 seconds
Time Before: 0.01070 seconds
Time After: 0.01543 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02134 seconds
Time After: 0.02155 seconds
Time Before: 0.02344 seconds
Time After: 0.02466 seconds
Time Before: 0.02796 seconds
Time After: 0.02813 seconds
Time Before: 0.03025 seconds
Time After: 0.03168 seconds
UPDATE session SET lastactivity = 1776640115, location = '/forums/private.php?do=newpm&explain=1&u=98490' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04415 seconds
Time After: 0.04446 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
