Time Before: 0.01840 seconds
Time After: 0.02618 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02627 seconds
Time After: 0.02669 seconds
Time Before: 0.02692 seconds
Time After: 0.02705 seconds
Time Before: 0.02786 seconds
Time After: 0.03041 seconds
Time Taken: 0.00255 seconds
Time Before: 0.02710 seconds
Time After: 0.03432 seconds
Time Taken: 0.00722 seconds
Time Before: 0.04137 seconds
Time After: 0.04180 seconds
Time Before: 0.04499 seconds
Time After: 0.04626 seconds
Time Before: 0.04065 seconds
Time After: 0.04654 seconds
Time Taken: 0.00589 seconds
Time Before: 0.08766 seconds
Time After: 0.08786 seconds
Time Before: 0.10412 seconds
Time After: 0.10539 seconds
End call of global.php: 0.10744285583496
Time Before: 0.11674 seconds
Time After: 0.11695 seconds
Time Before: 0.11975 seconds
Time After: 0.12125 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1776749549, location = '/forums/private.php?do=newpm&explain=1&u=98561'
Time Before: 0.13977 seconds
Time After: 0.14009 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.13878202438354 seconds with 9 queries, spending 0.0082921981811523 doing MySQL queries and 0.13048982620239 doing PHP things.
