Time Before: 0.01372 seconds
Time After: 0.02212 seconds
Time Taken: 0.00840 seconds
Time Before: 0.02225 seconds
Time After: 0.02457 seconds
Time Taken: 0.00232 seconds
Time Before: 0.02517 seconds
Time After: 0.02532 seconds
Time Before: 0.02621 seconds
Time After: 0.02893 seconds
Time Taken: 0.00272 seconds
Time Before: 0.02540 seconds
Time After: 0.03284 seconds
Time Taken: 0.00744 seconds
Time Before: 0.04263 seconds
Time After: 0.04287 seconds
Time Before: 0.04562 seconds
Time After: 0.04681 seconds
Time Before: 0.04186 seconds
Time After: 0.04701 seconds
Time Taken: 0.00515 seconds
Time Before: 0.08226 seconds
Time After: 0.08239 seconds
Time Before: 0.44898 seconds
Time After: 0.45027 seconds
End call of global.php: 0.45319604873657
Time Before: 0.45896 seconds
Time After: 0.45913 seconds
Time Before: 0.46274 seconds
Time After: 0.46421 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=98580'
Time Before: 0.48464 seconds
Time After: 0.48488 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.4835250377655 seconds with 9 queries, spending 0.009915828704834 doing MySQL queries and 0.47360920906067 doing PHP things.
