Time Before: 0.00216 seconds
Time After: 0.00343 seconds
Time Before: 0.00350 seconds
Time After: 0.00403 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00430 seconds
Time After: 0.00445 seconds
Time Before: 0.00570 seconds
Time After: 0.01002 seconds
Time Taken: 0.00431 seconds
Time Before: 0.00453 seconds
Time After: 0.01474 seconds
Time Taken: 0.01021 seconds
Time Before: 0.01682 seconds
Time After: 0.01706 seconds
Time Before: 0.01967 seconds
Time After: 0.02096 seconds
Time Before: 0.01624 seconds
Time After: 0.02122 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02836 seconds
Time After: 0.02855 seconds
Time Before: 0.03045 seconds
Time After: 0.03171 seconds
End call of global.php: 0.033878087997437
Time Before: 0.03510 seconds
Time After: 0.03526 seconds
Time Before: 0.03741 seconds
Time After: 0.03989 seconds
Time Taken: 0.00248 seconds
SET lastactivity = 1789142386, location = '/forums/private.php?do=newpm&explain=1&u=98623', badlocation = 1
Time Before: 0.05390 seconds
Time After: 0.05422 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.052554130554199 seconds with 9 queries, spending 0.010930776596069 doing MySQL queries and 0.04162335395813 doing PHP things.
