Time Before: 0.00143 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00240 seconds
Time Before: 0.00265 seconds
Time After: 0.00281 seconds
Time Before: 0.00373 seconds
Time After: 0.00640 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00289 seconds
Time After: 0.01198 seconds
Time Taken: 0.00909 seconds
Time Before: 0.01461 seconds
Time After: 0.01483 seconds
Time Before: 0.01729 seconds
Time After: 0.01849 seconds
Time Before: 0.01385 seconds
Time After: 0.01872 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02506 seconds
Time After: 0.02520 seconds
Time Before: 0.02757 seconds
Time After: 0.02880 seconds
Time Before: 0.03249 seconds
Time After: 0.03265 seconds
Time Before: 0.03468 seconds
Time After: 0.03610 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=99018', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05094 seconds
Time After: 0.05120 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
