Time Before: 0.02590 seconds
Time After: 0.03457 seconds
Time Taken: 0.00867 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.03465 seconds
Time After: 0.03519 seconds
Time Taken: 0.00054 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.03542 seconds
Time After: 0.03559 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.03630 seconds
Time After: 0.03823 seconds
Time Taken: 0.00194 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.03566 seconds
Time After: 0.04264 seconds
Time Taken: 0.00698 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.05509 seconds
Time After: 0.05558 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.05702 seconds
Time After: 0.05827 seconds
Memory Before: 2,146.711 KB
Memory After: 2,146.570 KB
Time Before: 0.05421 seconds
Time After: 0.05855 seconds
Time Taken: 0.00434 seconds
Memory Before: 2,126.828 KB
Memory After: 2,259.922 KB
Memory Used: 133.094 KB
Time Before: 0.11311 seconds
Time After: 0.11332 seconds
Memory Before: 2,813.445 KB
Memory After: 2,813.961 KB
Time Before: 0.13301 seconds
Time After: 0.13428 seconds
Memory Before: 2,901.734 KB
Memory After: 2,902.328 KB
End call of global.php: 0.13680601119995
Time Before: 0.14702 seconds
Time After: 0.14719 seconds
Memory Before: 3,538.516 KB
Memory After: 3,538.945 KB
Time Before: 0.14978 seconds
Time After: 0.15128 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,820.047 KB
Memory After: 3,821.734 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=99117', badlocation = 1
Time Before: 0.17401 seconds
Time After: 0.17429 seconds
Memory Before: 4,298.453 KB
Memory After: 4,298.680 KB
Page generated in 0.17300009727478 seconds with 9 queries, spending 0.0078427791595459 doing MySQL queries and 0.16515731811523 doing PHP things.
