Time Before: 0.00950 seconds
Time After: 0.01183 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01192 seconds
Time After: 0.01237 seconds
Time Before: 0.01257 seconds
Time After: 0.01273 seconds
Time Before: 0.01349 seconds
Time After: 0.01556 seconds
Time Taken: 0.00207 seconds
Time Before: 0.01279 seconds
Time After: 0.02007 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02509 seconds
Time After: 0.02554 seconds
Time Before: 0.02806 seconds
Time After: 0.02929 seconds
Time Before: 0.02430 seconds
Time After: 0.02957 seconds
Time Taken: 0.00527 seconds
Time Before: 0.04436 seconds
Time After: 0.04449 seconds
Time Before: 0.05341 seconds
Time After: 0.05463 seconds
End call of global.php: 0.057361841201782
Time Before: 0.06162 seconds
Time After: 0.06179 seconds
Time Before: 0.06440 seconds
Time After: 0.06585 seconds
SET lastactivity = 1776539931, location = '/forums/private.php?do=newpm&explain=1&u=99130'
Time Before: 0.08479 seconds
Time After: 0.08517 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.083714962005615 seconds with 9 queries, spending 0.0077123641967773 doing MySQL queries and 0.076002597808838 doing PHP things.
