Time Before: 0.00136 seconds
Time After: 0.00182 seconds
Time Before: 0.00190 seconds
Time After: 0.00236 seconds
Time Before: 0.00260 seconds
Time After: 0.00274 seconds
Time Before: 0.00377 seconds
Time After: 0.00634 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00282 seconds
Time After: 0.01075 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01274 seconds
Time After: 0.01326 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01652 seconds
Time After: 0.01771 seconds
Time Before: 0.01198 seconds
Time After: 0.01793 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02479 seconds
Time After: 0.02494 seconds
Time Before: 0.02731 seconds
Time After: 0.02868 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.031405925750732
Time Before: 0.03287 seconds
Time After: 0.03301 seconds
Time Before: 0.03515 seconds
Time After: 0.03655 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=99190', badlocation = 1
Time Before: 0.05016 seconds
Time After: 0.05046 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.04925799369812 seconds with 9 queries, spending 0.0082569122314453 doing MySQL queries and 0.041001081466675 doing PHP things.
