Time Before: 0.02262 seconds
Time After: 0.03193 seconds
Time Taken: 0.00932 seconds
Time Before: 0.03202 seconds
Time After: 0.03246 seconds
Time Before: 0.03269 seconds
Time After: 0.03281 seconds
Time Before: 0.03356 seconds
Time After: 0.03601 seconds
Time Taken: 0.00245 seconds
Time Before: 0.03288 seconds
Time After: 0.04040 seconds
Time Taken: 0.00752 seconds
Time Before: 0.05098 seconds
Time After: 0.05118 seconds
Time Before: 0.05362 seconds
Time After: 0.05486 seconds
Time Before: 0.05025 seconds
Time After: 0.05509 seconds
Time Taken: 0.00485 seconds
Time Before: 0.09935 seconds
Time After: 0.09951 seconds
Time Before: 0.12220 seconds
Time After: 0.12345 seconds
End call of global.php: 0.12579298019409
Time Before: 0.13437 seconds
Time After: 0.13467 seconds
Time Before: 0.13736 seconds
Time After: 0.13886 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1783125264, location = '/forums/private.php?do=newpm&explain=1&u=99312'
Time Before: 0.15793 seconds
Time After: 0.15824 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.15688705444336 seconds with 9 queries, spending 0.0079681873321533 doing MySQL queries and 0.14891886711121 doing PHP things.
