Time Before: 0.02055 seconds
Time After: 0.02618 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02625 seconds
Time After: 0.02674 seconds
Time Before: 0.02701 seconds
Time After: 0.02717 seconds
Time Before: 0.02807 seconds
Time After: 0.02998 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02725 seconds
Time After: 0.03416 seconds
Time Taken: 0.00691 seconds
Time Before: 0.03909 seconds
Time After: 0.03965 seconds
Time Taken: 0.00056 seconds
Time Before: 0.04246 seconds
Time After: 0.04376 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03830 seconds
Time After: 0.04398 seconds
Time Taken: 0.00569 seconds
Memory After: 2,261.836 KB
Time Before: 0.06789 seconds
Time After: 0.06805 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08988 seconds
Time After: 0.09112 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.093565940856934
Time Before: 0.10469 seconds
Time After: 0.10485 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10767 seconds
Time After: 0.10957 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789108885, location = '/forums/private.php?do=newpm&explain=1&u=99384', badlocation = 1
Time Before: 0.12859 seconds
Time After: 0.12909 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.12720394134521 seconds with 9 queries, spending 0.0083918571472168 doing MySQL queries and 0.118812084198 doing PHP things.
