Time Before: 0.01534 seconds
Time After: 0.02227 seconds
Time Taken: 0.00693 seconds
Time Before: 0.02239 seconds
Time After: 0.02277 seconds
Time Before: 0.02301 seconds
Time After: 0.02339 seconds
Time Before: 0.02422 seconds
Time After: 0.02665 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02345 seconds
Time After: 0.03146 seconds
Time Taken: 0.00801 seconds
Time Before: 0.03929 seconds
Time After: 0.03976 seconds
Time Before: 0.04116 seconds
Time After: 0.04242 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03857 seconds
Time After: 0.04263 seconds
Time Taken: 0.00406 seconds
Memory After: 2,261.836 KB
Time Before: 0.07047 seconds
Time After: 0.07078 seconds
Memory Before: 2,815.352 KB
Memory After: 2,815.867 KB
Time Before: 0.08663 seconds
Time After: 0.08788 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
Time Before: 0.09528 seconds
Time After: 0.09545 seconds
Memory Before: 3,540.313 KB
Memory After: 3,540.742 KB
Time Before: 0.09784 seconds
Time After: 0.09930 seconds
Memory Before: 3,821.891 KB
Memory After: 3,823.578 KB
UPDATE session SET lastactivity = 1788874143, location = '/forums/private.php?do=newpm&explain=1&u=996' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12303 seconds
Time After: 0.12336 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.719 KB
