Time Before: 0.01082 seconds
Time After: 0.01294 seconds
Time Taken: 0.00212 seconds
Time Before: 0.01304 seconds
Time After: 0.01342 seconds
Time Before: 0.01363 seconds
Time After: 0.01375 seconds
Time Before: 0.01452 seconds
Time After: 0.01708 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01380 seconds
Time After: 0.02172 seconds
Time Taken: 0.00792 seconds
Time Before: 0.02627 seconds
Time After: 0.02664 seconds
Time Before: 0.02917 seconds
Time After: 0.03042 seconds
Time Before: 0.02548 seconds
Time After: 0.03063 seconds
Time Taken: 0.00515 seconds
Time Before: 0.05233 seconds
Time After: 0.05248 seconds
Time Before: 0.06207 seconds
Time After: 0.06335 seconds
End call of global.php: 0.065931797027588
Time Before: 0.07023 seconds
Time After: 0.07040 seconds
Time Before: 0.07287 seconds
Time After: 0.07432 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=99618'
Time Before: 0.09212 seconds
Time After: 0.09236 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.090957880020142 seconds with 9 queries, spending 0.0079729557037354 doing MySQL queries and 0.082984924316406 doing PHP things.
