Time Before: 0.01105 seconds
Time After: 0.01366 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01375 seconds
Time After: 0.01427 seconds
Time Before: 0.01454 seconds
Time After: 0.01470 seconds
Time Before: 0.01556 seconds
Time After: 0.01851 seconds
Time Taken: 0.00296 seconds
Time Before: 0.01478 seconds
Time After: 0.02298 seconds
Time Taken: 0.00820 seconds
Time Before: 0.02688 seconds
Time After: 0.02711 seconds
Time Before: 0.02976 seconds
Time After: 0.03109 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02621 seconds
Time After: 0.03133 seconds
Time Taken: 0.00512 seconds
Time Before: 0.04405 seconds
Time After: 0.04455 seconds
Time Before: 0.06372 seconds
Time After: 0.06495 seconds
End call of global.php: 0.066903829574585
Time Before: 0.07319 seconds
Time After: 0.07337 seconds
Time Before: 0.07626 seconds
Time After: 0.07786 seconds
Time Taken: 0.00160 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=99638', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.09673 seconds
Time After: 0.09699 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.095662832260132 seconds with 9 queries, spending 0.0089688301086426 doing MySQL queries and 0.086694002151489 doing PHP things.
