Time Before: 0.00147 seconds
Time After: 0.00210 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00219 seconds
Time After: 0.00265 seconds
Time Before: 0.00289 seconds
Time After: 0.00306 seconds
Time Before: 0.00383 seconds
Time After: 0.00631 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00314 seconds
Time After: 0.00970 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01203 seconds
Time After: 0.01239 seconds
Time Before: 0.01498 seconds
Time After: 0.01619 seconds
Time Before: 0.01131 seconds
Time After: 0.01644 seconds
Time Taken: 0.00512 seconds
Time Before: 0.02313 seconds
Time After: 0.02334 seconds
Time Before: 0.02545 seconds
Time After: 0.02670 seconds
End call of global.php: 0.029034852981567
Time Before: 0.03044 seconds
Time After: 0.03065 seconds
Time Before: 0.03340 seconds
Time After: 0.03566 seconds
Time Taken: 0.00226 seconds
SET lastactivity = 1776684653, location = '/forums/private.php?do=newpm&explain=1&u=99645', badlocation = 1
Time Before: 0.05169 seconds
Time After: 0.05199 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.050766944885254 seconds with 9 queries, spending 0.0088884830474854 doing MySQL queries and 0.041878461837769 doing PHP things.
