Time Before: 0.02662 seconds
Time After: 0.03130 seconds
Time Taken: 0.00468 seconds
Time Before: 0.03141 seconds
Time After: 0.03197 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03231 seconds
Time After: 0.03246 seconds
Time Before: 0.03335 seconds
Time After: 0.03574 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03254 seconds
Time After: 0.04005 seconds
Time Taken: 0.00751 seconds
Time Before: 0.05288 seconds
Time After: 0.05313 seconds
Time Before: 0.05530 seconds
Time After: 0.05650 seconds
Time Before: 0.05222 seconds
Time After: 0.05674 seconds
Time Taken: 0.00452 seconds
Time Before: 0.10481 seconds
Time After: 0.10508 seconds
Time Before: 0.12457 seconds
Time After: 0.12594 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.12791705131531
Time Before: 0.13840 seconds
Time After: 0.13865 seconds
Time Before: 0.14099 seconds
Time After: 0.14250 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1776602237, location = '/forums/private.php?do=newpm&explain=1&u=99655'
Time Before: 0.16472 seconds
Time After: 0.16499 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.16362500190735 seconds with 9 queries, spending 0.0082261562347412 doing MySQL queries and 0.15539884567261 doing PHP things.
