Time Before: 0.01226 seconds
Time After: 0.01850 seconds
Time Taken: 0.00624 seconds
Time Before: 0.01860 seconds
Time After: 0.01898 seconds
Time Before: 0.01924 seconds
Time After: 0.01989 seconds
Time Taken: 0.00065 seconds
Time Before: 0.02142 seconds
Time After: 0.02364 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01996 seconds
Time After: 0.02770 seconds
Time Taken: 0.00774 seconds
Time Before: 0.03539 seconds
Time After: 0.03578 seconds
Time Before: 0.03887 seconds
Time After: 0.04011 seconds
Time Before: 0.03461 seconds
Time After: 0.04036 seconds
Time Taken: 0.00575 seconds
Time Before: 0.06575 seconds
Time After: 0.06590 seconds
Time Before: 0.07512 seconds
Time After: 0.07639 seconds
End call of global.php: 0.07875394821167
Time Before: 0.08416 seconds
Time After: 0.08432 seconds
Time Before: 0.08706 seconds
Time After: 0.08855 seconds
SET lastactivity = 1789040987, location = '/forums/private.php?do=newpm&explain=1&u=99772', badlocation = 1
Time Before: 0.10983 seconds
Time After: 0.11021 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.10870790481567 seconds with 9 queries, spending 0.0083301067352295 doing MySQL queries and 0.10037779808044 doing PHP things.
