Time Before: 0.01251 seconds
Time After: 0.01761 seconds
Time Taken: 0.00511 seconds
Time Before: 0.01774 seconds
Time After: 0.01831 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01864 seconds
Time After: 0.01881 seconds
Time Before: 0.01962 seconds
Time After: 0.02334 seconds
Time Taken: 0.00373 seconds
Time Before: 0.01888 seconds
Time After: 0.02795 seconds
Time Taken: 0.00907 seconds
Time Before: 0.03547 seconds
Time After: 0.03590 seconds
Time Before: 0.03732 seconds
Time After: 0.03855 seconds
Time Before: 0.03473 seconds
Time After: 0.03879 seconds
Time Taken: 0.00406 seconds
Time Before: 0.06868 seconds
Time After: 0.06886 seconds
Time Before: 0.07976 seconds
Time After: 0.08104 seconds
End call of global.php: 0.083356857299805
Time Before: 0.09166 seconds
Time After: 0.09185 seconds
Time Before: 0.09429 seconds
Time After: 0.09583 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1776877483, location = '/forums/private.php?do=newpm&explain=1&u=99875'
Time Before: 0.11605 seconds
Time After: 0.11648 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.11494493484497 seconds with 9 queries, spending 0.0097343921661377 doing MySQL queries and 0.10521054267883 doing PHP things.
