Time Before: 0.01937 seconds
Time After: 0.02573 seconds
Time Taken: 0.00635 seconds
Time Before: 0.02583 seconds
Time After: 0.02625 seconds
Time Before: 0.02648 seconds
Time After: 0.02663 seconds
Time Before: 0.02757 seconds
Time After: 0.03037 seconds
Time Taken: 0.00280 seconds
Time Before: 0.02672 seconds
Time After: 0.03598 seconds
Time Taken: 0.00926 seconds
Time Before: 0.04344 seconds
Time After: 0.04385 seconds
Time Before: 0.04676 seconds
Time After: 0.04806 seconds
Time Before: 0.04263 seconds
Time After: 0.04834 seconds
Time Taken: 0.00571 seconds
Time Before: 0.06964 seconds
Time After: 0.06981 seconds
Time Before: 0.08140 seconds
Time After: 0.08269 seconds
Time Before: 0.09125 seconds
Time After: 0.09140 seconds
Time Before: 0.09390 seconds
Time After: 0.09532 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=99945' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.11335 seconds
Time After: 0.11364 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
